idleprocess
Gave in to temptation on Prime Day and grabbed one of these in neutral white.
TL;DR: The Thrunite Archer 2A V3 is a general-purpose light suitable for most casual flashlight tasks, but doesn't necessarily exceed at any one thing.
THE GOOD
THE BAD
THE UGLY
Personal opinion
I'm not sure why the 2xAA formfactor is still around. In theory you can get double the runtime or double the output, but but we're long past the mini-maglite days when the difference between 2xAA and 1xAA was literally ~15 lumens vs ~1 lumen. Does it really matter for casual usage if you get ~17 lumens for 22 hrs vs 51 hrs or ~70 lumens for 5 hrs vs 11 hrs? How many manufacturers are taking advantage of double the power to up the output meaningfully?
I'll deploy the light to one of my bags - work bag or bugout bag - where it will replace an 18650 or 123A light and I can switch to commonly-available AAs.
THE GOOD
- Mode arrangement is logical: low is sublumen with the other 3 modes being reasonably spaced. The strobe setting requires a ~1s press. The driver features mode memory.
- If the driver users PWM dimming, it's not apparent
- Beam is reasonably broad while still illuminating at 'across the front yard' distance on high
- Orange peel reflector smooths out the hotspot
- Tail switch is a forward clicky, allowing for momentary-on as well as physical disconnection of power
- The light will run on one cell without complaint (I expect it produces less light on higher modes)
- Accepts NiMH cells slightly larger in diameter than alkaline AAs
- Neutral white tint lacks the angry blue typical of inexpensive LED flashlights
THE BAD
- It is apparent that the design is an extended version of the 1A - the body tube is a near-featureless extension for the second cell while the first cell section closely resembles the 1xAA Archer 1A. The lack of knurling on the back half makes it slippery-er than it should be.
- The mid-body pocket clip location is kind of useless for head-down carry unless the pocket you're clipping it to is the same depth; it might be more useful clipping around for head-up carry in a deep pocket
- The light is so long that one must hold the light either at the back end to switch it on/off or closer to the front to switch modes - and I've got pretty large hands
THE UGLY
- Despite apparent design intent to allow the light to tailstand, the switch boot is a fraction of a mm too long to tailstand reliably
Personal opinion
