Biodarren
I know they use the same emitter but the catapult is rated at much higher output.
Which one is worthy of my hard earned cash???
The catapult doesnt have anything special other than the emitter.. the beam is rather sharp so will not do very well at indoors or close range use.
Get the M21 if you had to choose between those 2.
For a police officer the M21 is hands down a better choice for daily duty carry. You might also consider an M30 - but IMO the Catapult is too large for a duty light.
Hmm, I haven't tried swapping heads but I'd bet they LEGO. Whatchya thinking?
Unless you've been carrying a Magcharger or Ultrastinger on your belt...
I would love to see some beam shots if you can get a camera!!
I think i am swaying towards the Catapult at the moment. It just looks like a very well made light that should be able to put up with any potential knocks that may come its way when i'm on duty.
I got my M21 today. The beam is similar to my M30 with a large hot spot and bright spill. The spill is not as wide as the M30 and the transition from spot to spill is very smooth. It is not going to be anything close to a thrower. Just from a initial white wall hunt, it does produce lots of light for it's size. Comparing it to two lights I have with similar beam patterns, I would put it somewhere in the middle of my PD30 and my M30. 350 lumens, maybe a bit more. The beam is very good. It is smooth and centered. Fit and finish is typical Olight. I am looking forward to seeing what it can do outside tonight. I wish I could snap a couple of pictures for you, but my camera isn't working.
