Just got a ThrunNite TC15 which has a CREE XHP 35 LED. Great light.
Very bright but a problem. When I put it on the higher setting, it goes off. If I replace the battery with a plain old Panasonic cell with no protection circuit it works just fine. It seems that on high, the amperage is high enough to activate the cut out. All my older ThruNite 18650s with a protection circuit shut down when I go to the Turbo mode. It will not power back up in a lower mode until I replace the battery. It runs just fine in the lower 3 power modes. Go high and it will shutdown and not power backup at all. Only batteries with protection will do this.
When I buy new cells, with protection how can I find out if they will work with my device. Are there specs I can find to show the max amperage they will handle?
