Mugrunty
- Joined
- Feb 12, 2007
- Messages
- 163
Hey guys,
(I'll be updating this post as I get more data! My discharge curve data is at home,so you'll have to wait until after work!)
I stopped by Harbor Freight Tools this past weekend and noticed they had some LSD NiMH batteries on sale (http://www.harborfreight.com/4-pack-aa-pre-charged-nimh-rechargeable-batteries-67861.html). I figured I buy a pack and see how well they measured up against my eneloops. I still had plenty of crappy energizer 2500mAh batteries to replace, and figured that these couldn't be any worse!
I did a quich search and didn't see any posts about these...
I ran a discharge curve on my iCharger @ 1 Amp and came up with these two graphs:
Each battery was in a AA holder, so there may be some voltage loss through the wires. I measured the cells with my DMM just for kicks, and the graph voltage never was off by more than -0.02V or so. I'm not entirely sure why the graphs jumps around like a stair case. It's like the precision changed throughout the discharge. I don't think the iCharger works very well with single cells.
I did a refresh and analyze a few times on my C9000 (@500mA discharge), but forgot the results of the magnum. I'm doing them again while writing down the voltage values throughout the discharge. I'll post some data when the magnum is finished.
Eneloop (09-0612): 1873mAh
Magnum: 2164mAh
So far, it seems the eneloop holds a higher discharge voltage in the beginning.
EDIT:
I did an Internal Resistance measurement using the iCharger as well.
Eneloop (charged): ~27 milliohms
Magnum (charged): ~46 milliohms
Magnum: 2164mAh
EDIT:
