Hello fellow CPF members.
Just recently i've purchased myself a Tiablo A9 from DX to find out that it was one of the fake models (If someone knows the final word a pm would be kewl - i'm just curious to see what happened).
Anyhow, back to topic. As I dismantle a vast number of things to get a feel for they are constructed I have done the same with my A9 and in the process lifted the XR-E's lense and now it has air bubbles underneath . Anyhow, rather than just buying a new one LED I figure I may aswell upgrade it at the same time.
In my traditional style i've skipped straight to the idea of bigger is better, and of course i'm looking at the SSC-P7.
I've seen an very well done A8 done by StefanFS. Very Nice! :rock:
https://www.candlepowerforums.com/threads/194753
Naturally I'll be using 18650 cells(for improved life over 16340's) and thus will be going the way of current regulation(naturally matching up my P7 with the voltage band of my battery). However, rather than employing the same method of driving the P7 seen stefanFS' A8, i was thinking of going something with a bit more option in terms of performance range.
The Aforementiond Multi-level driver.
https://www.candlepowerforums.com/threads/192677
Rather than having two settings of Flameflower and "still rediculous" i was thinking of driving levels of around 2.8A (Max) - 1.4A (Med) - 0.7A (Low) which would still provide a large lumen count when wanted, but also give me a some respectable battery life when I don't need/need all those lumens.
I've looked around for a while with no success(it doesn't help that my internet is capped atm, 64k! - ouch). The main question would be is a single driver like this available?
If not, I have seen darkzero's "bigmac", and yes, while i know it probably won't fit in an A9(or at least easily - those boards in that pic look larger than most), would anyone be able to suggest two or three boards that can fit the quota?
Darkzero's bigmac design of joining boards seems to be more suited to my application, but I'm no driver expert, so any pointers would be helpful.
Any help would be GREATLY appreciated. :twothumbs:
Cheers!
Cheers!
