turbodog
Buy you a used APC unit off ebay. These things last forever.
turbodog said:The apc smart ups 700 is a nice unit. I've got it and a smart ups 1100 also. It's the smallest of the smart series.
The battery slides out the front and is easy to replace.
Apc's web site for this model:
http://www.apcc.com/resource/include/techspec_index.cfm?base_sku=SU700NET&language=en&LOCAL.APCCountryCode=WW=en&LOCAL.APCCountryCode=WW[/url]
I'm with bfg9000 on this one: Go oversized, the longer runtime is nice. Because of Peukert's phenomenon, batteries run at half the drain will give you more than twice the runtime:
If taken care of, battery can last five years. If abused, it's done in a month. The worst thing you can do is let it store unused without letting it charge every few months or not charging it completely. Left discharged, lead acid battery is quickly destroyed.I have to take exception to the "lasts forever" claim. As the battery ages or is abused by power failures, the cells tend to eventually short or go open. The batteries tend to swell, and (very seldom) leak a little gel. The unit heats up, which is deadly for electronics over long periods.
This is true for newer ones with the outlets and the top cover made of single piece molded plastic screwed onto plastic half. Smart-UPSs and older Back UPSs have a metal chassis and the outlets are of same Duplex type used on regular wall outlets, not contacts embedded into chassis.Yes, you can add a new battery and quite likly revive it, but many units are designed to be disposable. I have 9 UPSes around the house. I have 4 dead batteries currently waiting to go to the recyler. I have replaced teh batteries in most of them at least once.
APC Smart UPS XL series or any of the medium tower (the one that weighs 50 lbs) APC UPS is looking good.The $15 batteries that were mentioned are almost certainly NOT deep discharge. When a power failure hits the average UPS runs til the battery goes dead, and that may be pretty quick. A typical SLA will die after only a few (3 in one case) power failures because fo this abuse.
The bigger the battery capacity and better quality the battery (AGM are better than a plain SLA) the more power failures it will survive. I have a 1250va powering my workstation + monitor, and it's only pulling about 400 watts. It's set to shutdown after 5 minutes, or 20% discharge. The UPS runing my network equipment is set to run much longer since the load is only a few hundred watts.
I really need to get all of it running on a 48 volt battery bank liek the phone company uses.
Daniel
They have many different ways of rating batteries. Ah, Reserve Capacity, CCA, Watts @ 15 minute,etc.RE "oversized batteries"
Batteries are rated in "watthours" - the ability to deliver 1 watt for 1 hour, only it's a BIT of a lie. You can't draw 1 watt for 1 hour from a 1 watthour battery
NiMH and NiCd are usually rated at C/5Batteries (depending on chemistry) are rated at a discharge rate of either C/10 or C/20 - usually C/20 (where C is the watthour capacity of the battery) - for lead acid gel cells, figure C/20 - any faster than that, you get 1)Less capacity, and 2)you have a risk of damaging the batteries
...snip...
Maximum current is a separate spec. C is not the watt hour capacity. C is the Ah capacity.
