PhotonWrangler
One of the lesser understood causes of voltage spikes during power blackouts happens when the power goes off, not when it comes back on. At the instant that the AC transformers in line-powered devices are de-energized, the magnetic field suddenly collapses, inducing a sharp spike onto the line.
You can easily prove this yourself -
Find a pair of magnetic headphones, a neon bulb, a 9v battery and some alligator leads. Connect the neon bulb in parallel with the headphone's contacts. Then connect that parallel headphone-bulb combination across a 9v battery. Then disconnect the battery, and the neon bulb will flash at the very moment that the headphones are de-energized. The collapsing field in the headphone's coils produces a voltage spike that's waaaaay above 9 volts, enough to fire the neon bulb!
Oh by the way, do this with insulation between the leads and your fingers, otherwise you'll get a brief shock.
The point? Power energized = 9 volts. Power suddenly de-energized = voltage spike that's MUCH higher than the original applied voltage. Now imagine that incoming power line with all of those transformers, fridge motors and other coils connected across it - many collapsing magnetic fields causing a huge spike that's much higher than the original 120 volts. By the time the power goes off, you've already taken a huge spike.
