thunderlight
Recently discovered that Method daily shower cleaner available from Target removes that white powder generated by alkaline battery leaks.
I picked up an Eveready Captain that worked with 3 batteries. When I unscrewed the back, the spring was embedded in the rear alkaline battery. When I removed the battery, the spring was covered with the white powder residue left by leaking alkaline batteries. I started scraping off the powder. When I decided that this was taking too long, I applied Method and the powder completely dissolved. After applying the cleaner, make sure you dry out the treated parts.
