Tractorshaft
Tip to recover "Lost" typing, edits & "un-posted" postings in forums
Gents,
This probably is not in the right section of the forums but I have read so many posts where folks have "Lost" lots of work when their browser strays from the page they were inputting the data on
or you accidentally "Fat Finger" the keyboard or the cat jumps up and walks across your literary or technical masterpiece
before you "Submit" it?
I thought it appropriate in the most visited section per stats on CPF.
Here is the "Fix"!! Simply hold down your "CTRL" key and simultaneously press the "z" key. This will back you up to your "Lost" work :thumbsup:.
Here is the tip bolded;
IF YOU HAPPEN TO "STRAY" FROM THE PAGE YOU HAVE TYPED FURIOUSLY ON FOR AN HOUR AND THINK YOUR WORK IS LONG GONE TRY THIS LITTLE "TRICK" TO RESTORE YOUR WORK!
HOLD DOWN THE "ctrl" KEY AND SELECT THE "z" KEY AT THE SAME TIME, ctrl + z WILL CHRONOLOGICALLY BACK YOU OUT OF THE INADVERTENT KEYSTROKE OR NAVIGATION.
DO NOT! USE THE BACK ARROW KEY < ON THE BROWSER MENU! WE ALL KNOW THAT THIS DOES NOT WORK AS MOST TIMES IT "RE-SENDS" YOUR "COMMAND" INSTEAD OF "RESTORING" THE EDITOR SESSION YOU WERE WORKING ON FOR AN HOUR.
Hope this helps someone out in the future! Try it so you know what to expect! Mnemonically, "CTRL Z, it saved me!"
Enjoy
Jerry
Gents,
Enjoy
Jerry
