Gunner12
If the head/bezel is tight, press the button down until it clicks and let go(click the switch) and the light will be on turbo. If the head/bezel is loose, clicking the switch will give you low mode, so tighten the head first then click and you'll get turbo.
When the light is turned on in general mode, tightening the head also gives you a constant turbo.
