bedazzLED
Up until recently I have been using Duracell Alkalines in my TK40 and they work well. I have been researching info on the best batteries for the TK40 and nearly every response in the forum indicate that Eneloops are by far the best to use.
I went out and purchased 16 Eneloops, put them through a recharge cycle to make sure they were all at the same voltage level. I then measured the voltage of each and they were all indeed at the same voltage.
So out came the Alkalines, in went the Eneloops, on went the TK40, big burst of light, a few flashes, and no light!
I checked to make sure the batteries were in the correct direction and all was OK. I checked everything was nice and tight and all was OK.
Just no light!
I put in the Alkalines and still no light.
I sat there and pondered this slight catastrophe. After a few minutes I thought I'd click the TK40 button just one more time before I put up the R.I.P. sign, and LIGHT!
I turned it off/on a few times and it flickered on and off a few times, but after a while it came back to life.
I flicked through the modes, tried the beacon, the blinking, the strobe and all was OK.
Not sure what the blazes happened, but all seems OK on Alkalines now, high mode is just as high as ever, and I'm VERY reluctant to try the Eneloops again.
Just thought I'd share my scare with you and ask if anybody might have an idea what might be the problem.
Looks like the Polestar will get the next try-out with the Eneloops before I risk my pride-and-joy again.
Regards,
bedazzLED.
Just no light!
Regards,
bedazzLED.
