Northern Lights
I blew the 1st position LED on my TM-800X3 while running it on 4 PowerX C's instead of 3D Alkalines. Time to upgrade to a Cree. I intend to replace all three LUX IIIs. I have another TM-800X3 with a damaged #1 that has a crinkled die, happened while experimenting with over voltage so I will move over one of these Lux III's salvaged from this upgrade.
These lights can be very difficult to open. The threads are glued. I opened one after leaving it a few months in the car in Arizona summer heat. The glue decomposed.
I intend to put 3 Cree stars into the damaged light. This one: http://www.szwholesale.com/32v36v-super-bright-42180-p-904.html
What do you think about this or recommend?
What I really like about these lights is that the 3 reflectors are perfectly aligned, collimated convergence, being molded in one piece. I do not know the resistor values because the bins can be different on these lights and I think they were constructed according to the needs of the bin. Once open I will know and can change them. The source voltage is 4.8 V NiMh, 4 C's
Here are two references, photos too:
http://candlepowerforums.com/vb/showthread.php?t=111651&highlight=tm-800x3
http://candlepowerforums.com/vb/showthread.php?t=77178
http://www.shykuang.com.tw -you can find it through here, I have trouble opening the pages
