stfc69
TN40Svn now on skylumen...
Oh heck yeah! Forget what I said about skipping TN40vn & going straight to X65vn. At this attractive price of the TN40Svn, Spec 2 competes well with the X65vn, bang for the buck wise.TN40Svn now on skylumen...
Oh heck yeah! Forget what I said about skipping TN40vn & going straight to X65vn. At this attractive price of the TN40vnS, Spec 2 competes well with the X65vn, bang for the buck wise.
... And it is now significantly less expensive!Wow mad putting that into perspective that's a crazy bright light in every way. Sweeeeeeeet!!
Anyone have any idea the heatsink ability of the TN40vn vs the TK75vnQ? Which is more efficient at getting rid of the heat? I know one generates more heat vs the other just due to led but taking that out of consideration which heatsinks better? Thanks all.
Vinh if you have insight with this chime in if you want.
I'm debating about upgrading my TK75vnQ to the TN40Svn since the hi emitter gives more illuminated spill vs a dedomed xml2 plus it's 3000 lumen and probably 200k more lux than my TK75vnQ so it's not a minor upgrade.
What are the numbers to your tk75vnQ? I don't think vinh redid the numbers to that light since he recalibrated his new light sphere with all new numbers to mostly just his newer releases lights. But if your light is not in the t6vn territory, I think it's a worth it kinda upgrade. I'm considering buying a tn40vns to upgrade my tm16gtvn and it has 422 kcd and 6000 lumens. Very similar to the t6vn. And if this thrunite has the same heat sinking abilities like his counterpart the tn46utvn, then I must say the tn40s has very good heatsinking....because the tn36vn and tn36utvn are the best I've seen in the same size same style lights.
+1 Would like to know how well of heat management on this TN40SVN.
From what I learned it has a thermal path equal to the TK75vnQ which is excellent. It will get hot quick since on turbo...you know...8700 lumen with excellent heat pathing at a medium mass light vs say the X65vn or RC40vnT which are much heavier. If I remember correctly 50% will get fairly warm in about 3-5 mins in normal room temp of ~68 which isn't surprising. 50% is probably close to the same output as my TK75vnQ at 100% which takes about 3-5 mins to get hot (50*Celsius). With mode group 11 there are 6 outputs so the first three would work well and should be plenty bright for most uses. Turbo with this light would be short bursts which in my opinion is the purpose of turbo.
