Finally got enough time and ease of mind to scratch another small project off of my "to-do-list"... Surefire M1 IR Illuminator LED module... or just: eMt1 !!!
It's not perfect solution, there is a narrowing part just underneath the lens that will block about 10% of light bouncing off of the reflector... and hopefully don't ruin beam profile in the process... will know in next day or two if focus and beam is worth the trouble...
Other than that, it should be a nice platform to run Nichia 219B or XPG2 or XPE2 at 1.4 Amps with custom modes and optimized for IMR 16340 cell (or 18350 if anyone goes step forward and bores his/her body - I sure won't, lol)...
really nice, my friend!
what i miss at the pic is a + spring or is there a flat bottom?
please share a beamshot if possible! i would like to change my m1 from infrared into only "red".
Any update on the eMt6 module?.
Im also curious about updates on the M6 modules.
Sorry guys... the lack of a good driver is what prevents this project... it's rather hard to find any buck driver with just simple low/med/high but it's hard to hit one that drives the LED with enough amperage (or drives it too hard), usually have too low voltage cut off to my taste for 3S combinations (ideal would be 5.5V) and usually are controlled with rather low PWM...
So... it's not off the shelves but until I can make something GOOD, it will have to wait and let other projects that are doable now to happen... like this eMt1...
Hi Tana, will this work in a KL6 Head, the Kind that's on a SF L6 and Porker?
Thanks Tana, you title says M4, are the eMt3 Drop-ins compatible With M4 lights?
Hi Tana, will this work with 2x26500s in series or 2x18650s in Parallel? I want to use an M3 Bezel on an M6 body.
Thanks!
