Bimmerboy
I recently picked up a super cheap, 2AA, 8 LED light containing what I can only assume is a little boost circuit (just started learning a bit of electronics, and still don't know much). I have a couple questions regarding running it on 3AAA in a different, and also super cheap host.
IIUC, putting 4.5V through it will run the LED's direct drive (and of course, overdriven, which is the plan), but first question... is this likely to cook the board in a fairly short time? I'm still gonna' find out the old fashioned way, but just figured I'd ask first.
And second question... assuming the boost can withstand 50% more V than it's designed for... when the batteries get down to around 3V, and are almost dead, the boost should then take over and drain the very last ounce of juice out of the AAA's, and give useable light to the very end, correct?
