Wok
The vehicle is a 2003 model[ I believe its Tacoma in USA] & has a H4, 200mm x 132mm housing. The supply harness has been upgraded.
Q: Can I expect significantly better performance from aftermarket housing + bulb c.f with new OEM units?
The aftermarket housing I have found in Australia is the Narva 72086 + bulb of choice eg 48872BL [ +50 65/55W] I notice Narva have a "Platinum 4300K" now but no reviews.There is also a 100/55W bulb but its not ' +50' type ? Sounds ideal ratio for me.
The Hellas are not readily available & more $.
The Cibies could not be traced here.
Suggestions/comments?
Thks....eng hoe
Thks....eng hoe
