65535
Thinking of modding a SF incan to run Tri Cree LED head at currents from 90mA-3000mA for the cluster, it would need a beefy heatsink and a special middle ring between the head and bezel to house a U2-esk selector ring with a Hall sensor creating seemless transition from low to high in infinite steps, It would ideally run on a rather large selection of cells, 3-4 cr123's, 2 17670's , or 2 17500's, using an A19 single cell extender. I wanna make this happen as I love working on things, I hope after some initially testing of electronics to control the power level I can make thie a reality.
Well new info is shark board with 18650 or 18500's and 17**0 cells with a .5mm thick sleeve. its range is 50-980ma so it'll suck some power, the hall sensor will take a little power for itself but nothing much.
Lumens should range from about 30-50 on low to 600 on high and anywhere inbetween
Well thats all for now,
