The last two graphs in the link to your RCR123A tests are very confusing and unusual. The 2nd to last uses very unusual x and y coordinates. I'm not sure what it means since normally a capacity test is done at a constant amp draw and voltage is measured until it falls below a specific point indicating end of life. Then you plot voltage vs time or equivalently voltage vs the running mAh. It doesn't make any sense in your graph that mAh is zero at the end of battery life. In the last graph, I seriously doubt that you are drawing 150A, which is the top of the scale for your Y-axis.
Further, that link still provides no explanation as to how you calculate your mAh capacities. All I can think of is that you are doing some sort of numerical integration of your amps vs time curve. But since the data points are so spread out, I can't see that as being accurate to more than one significant digit, while you express the capacity in 3 significant digits.
Finally, when you write out a fractional number, the leading digit is a zero ("0"), not the letter "o". Thus, such a number is written, for example, as 0.650 inches, not o.650 inches. It's a number, not a letter, regardless of the fact that many people say "oh" when they mean "zero".
