Re: Buy Trustfire SCC P7-C 2x18650 + Info
My Trustfire P7 arrived this morning.
It's a very mixed bag I'm afraid. I think that the best way to treat this torch is as a good usable blank.
My quick appraised during my work lunchtime is as follows :-
Metalwork. Pretty good. Has O-rings, finish is reasonably consistent in appearance, threads are good. Some v. small machine blemishes but very acceptable.
Output - not so good . Beam is purplish, output on RS 180-7133 light meter is 4100 lux at 1 metre (measured at 1metre). The current from the batteries is 1.1 amps peak, measured with a clamp ammeter. To determine the type of regulator cct, I drove the pill from a linear variable power supply. Results:-
7.5v in - 1.05 amps
7v in - 1.1amps
6v in - 1.05 amps
5.5v in - 600mA
5.0v in - 250mA
Thus, I surmise that the problem is a very bad linear regulator (I would expect the current to increase with decreasing voltage if it was a constant current PWM style regulator). So the maximum current the LED will see will be 1.1 amps in this case. Thus, the second battery really is wasted (especially as the regulation isn't particularly good either!)
From a thermal construction point of view, it looks pretty good with the LED bonded to a brass pill, which in turn is screwed into the reflector, which is screwed into the front bezel. Replacing the reflector will not be easy, though. Oh and the reflector works - hotspot a little larger than a P2D and no doughnut hole.
I would expect 9440 lux when this thing is driven at 2.8amps. Note that the glass is 89.7% transmission by measurement with/without so this could be an area of gain with a UCL lens, pushing it up to about 10,400.
Overall, disappointing - considering that I got 6000 lux with a P7 at 2 amps using a D-Mini smooth reflector with a larger hotspot (and with a reflector diameter of 28mm.
If anyone has other figures (lux etc) please postthem as I may have a duff unit (i.e. I cannot see if they isolated the Anode properley)
There you go. Must grab a bag of crisps now
HL
