Gatsby
I finally find a PEU bezel with Trits and am about to pimp my new (to me) 120P and ... you guessed it, in anticipation of the bezel arriving I took a shot at removing the old one. Mouse pad trick, shoes, door jamb, boiling water ... it isn't budging.
Having removed a Dereelight pill someone decided to lock into the reflector with red loctite, I know getting the Novatac bezel off is not going to be a fun task...
At this point, given the $4.95 replacement cost IIRC of a stock bezel - I'm about to sacrifice this one and apply the strap wrench, vice grip pliers...
Just for the record - before I apply the heavy ammunition - if I'm looking at the emitter (straight on to the light) the bezel screws into the light clockwise and unscrews by turning the bezel counter clockwise (normal threading for a screw into a nut) - correct?
Thanks!
As an aside - I wonder if there is any correlation to serial numbers? Mine is 13xxx ...
Thanks!
