James S
but even a buck a shower doesn't cut it to explain this.
Tell us more about this electric ceiling heat. i've seen radiant panels that you can mount on the ceiling which are actually very efficient, they dont heat the air much at all just radiate and keep YOU warm while you're under or in front of them. And so they dont use a lot of energy and are quite efficient.
But it sounds like you've got something else? I always think of electric heat as baseboard heaters like I had 10 years ago in a crappy little apartment in Chicago. It was so cold there one winter that frost formed on the INSIDE doorknob just from conducted heat out through the outside doorknob. I literally had hoarfrost on the inside of my apartment. I ran the electric heat that winter constantly though only up to about 65 and my electric bill was only $120 or so. Even figuring in 10 years of inflation that doesn't become $350.
Or they could just be dumping the bulk of their heat up through the attic and outside?
If the mixing tube in the hot water heater is rotted out then you'll end up running both elements even for just a small amount of hot water use, that can add up. Normally if you use only a little hot water only 1 of the 2 elements in a common electric water heater will come on, but if you use a lot both come on. And if the cold water doesn't get sent to the bottom of the tank properly with the mixing tube then they will both always come on.
Could something be leaking just enough hot water to keep your hot water heater running constantly?
