UI on a Fenix PxD with the tactical switch
snakyjake
WA, USA
Please explain the UI on a Fenix PxD with the tactical switch/clicky...and how it compares to the stock switch and UI.
The stock UI and switch is:
  • Twist bezel for general mode and turbo mode.
  • Full switch press = constant on/off.
  • Half press = output level and SOS on general mode. Strobe on/off on turbo mode.
With the tactical switch, I'm not sure if it includes momentary on/off. Or how to cycle through different output levels?
Thanks,
Jake
cycle via momentary click from unclicked position.
This is where I get confused. I thought a momentary press would give me momentary on, without changing output. Or are you saying that I get momentary on by half press, and cycle output by full presses? And the full presses won't get confused between constant on/off?
hey snaky...
multi mode and forward clickies aren't really meant to be together... it does kinda defeat the purpose of a momentary on when the light level changes...
it's only really useful on lights that use the clickie for on/off... and the bezel to switch levels...
KraZy
You half press from off to change modes, full click to stay. The Fenix UI + Forward clicky doesn't give you signal capability, just momentary on option.
