kevin812367 are you still there...we need you bud! Someone needs to put some sense back into this thread. Tell us what you want!
Ok, I will give you some thoughts...... (let's hope I do not go down in flames).
You can run a new K2 TFFC comfortable at 2.5amps... pretty easy for extended periods of time, in something that looks like a flashlight...ok, not a traditional flashlight, but that is what round CPU coolers are for I figure. This is a much nobler cause. I know you can run a Cree-XRE at 2A without any trouble either....and I am not even talking the fan running on the cooler, but I guess that would always be an option.
The heat sink I am using is about 3 -4 C/watt I would guess, maybe better. If I left the fan on, that drops to about 1. Remember this thing is used to cool 40 watt processors. So at 4C/watt, even at 10 watts into the LED, the rise in the heat sink at oh, perhaps 40C. 10 watts, 8C/watt for the K2 mounted very well... 80C, 25C ambient, that adds up to 145C...just a hair under the 150C maximum ambient..... (heck, you would think I designed it that way!).... So no catastrophic failure, but certainly the life will be well under 50,000 hours. I would expect perhaps 1,000 hour good life....and I can still drop it and not worry about it. The Cree at 2 amps should survive comfortably for a long time too.
Now I have not run either of these into an aspheric (and yes I think I would get 300+ lumens out of either), but I have run about a 130 lumen old K2 into one.
So, we are talking about "THROW" ....let's not get into arguments, I think the definition of the problem was clear. That said, what is throw? It is the ability to be able to illuminate distant object such that you can see clearly. Well that 130 lumen or so K2 is able to keep up with one of my 20 wattish Halogen lanterns on its ability to clearly illuminate distant objects such that I can see them. In some ways it is better because the tight beam does not let out much local light and kill my night vision.
So, my recommendation...cause I think you will be able to get the parts. Find two good aspheric lenses, and run an over-under Cree-Q5 at 2amps each. Run it off a lead-acid battery as they give you 10+ volts and are cheap not to mention two wires beats a battery holder.
For the heat sinks, go find yourself some older (smaller) round CPU coolers...Thermaltakes and the like.
I am not going to tell you how to mount the whole thing, but I figure cost is:
2 * Q5 = 18 (on stars)
2 * coolers = 15 (get the on clear out)
1 * Lead acid = 10
2 * aspheric = 20
That is $60. That gives you $40 to power it and figure out how to mount it. Don't ask me for driver suggestions as I role my own and am not up on what is ready available off the shelf.
Oh, beam shots are all I ask in return.....that and a picture.
Semiman
