Ultrafire 602c Q5
scoobybright
I have had this light for a little while now and Im very impressed with. Its super bright with CR123 rechargeables. Does anyone else have this flashlight and another that is any brighter that takes one CR123A Batteries?
This flashlight should be brighter Ultrafire MCU-C7s Cree Q5($13), I have this it's newer than your version, you can but it from bestofferbuy, I also have the Smallsun ZY-C81 (Q3)($10)which it cheaper and slightly less bright.
You can try the Ultrafire M1(Q5)($15) 3-mode which should be as bright as the MCU-C7, available at manafont or you can go for Ultrafire MCU-C7 Cree R5 LED 3-Mode, if you can spend $21, which will be the brightest off all.
