kosPap
hi all! Could the owners of these help me with a something?
I wish to modify one of these with a 1400mA driver and a forward clickie switch....
Before buying one I need to know if the Driver PCB is 17mm or soemthing else....Also if the switch is mounted on a PCB too. (usually one does not have to dissasemble the tailcap, if the switch is mounted the gfreen pcb is visible around the spring base)....
Thank you!!!!
Thank you!!!!
