Ultrafire Protected 18650 : Reliability, Quality
Grun
Has anyone used the Ultrafire Protected 18650's, 2400 mAh? How reliable are they? Do they work well? Quality issues or other problems, or are they pretty decent?
SilverFox has a recent thread here about these, pointing out some concerns. You might want to search for it and read his findings - he is one of the local (true) experts on batteries.
Aside from that I have used them for low power drain lights and have had no problems with them. They won't even get a glimmer out of my WF-500 incandescent, but work ok in my LED lights. - Larry
inconsistant=ultrafire i have found that to be true also, dang cheapskate that i am. poorest way to try and get some Matched cells for packmaking.
sometimes its a marvel, sometimes a dud, roll of the dice, i wish i had bought them in Vegas :)
The Ultrafires are quite simply crap.
Dont waste your money go for a decent battery (AW's) and you will never look back.
Grun - I said all the above, but the fact is I have quit buying them. I use what I have (two of the 18650's) as long as they work, but I've learned that good cells are more cost effective over the long haul. I now buy AW batteries, which are among the most expensive, but they work extremely well, last forever, and never let you down or ruin equipment. I think they are also far less dangerous for fire, etc. while charging. In the long run they cost no more than buying the cheapos and having to replace them much sooner (sometimes almost immediately). And the AW's will fire up the most power hungry incans out there. Of course I use only protected cells in any size or brand. Good luck with your lights. :) - Larry
I bought two blue Ultrafire 18650's from DX about 6 months ago. They both fire up a 2+ amp incan. nice and white, and a .75 amp LED, and charge fine on my WF-139.
I've only taken one of them to the cutoff voltage (accidentally, on the assumption that frequent charges are better), and it went out safely, then charged fine again to 4.2V. I've also tried shorting them (in a controlled environment), and the protection circuit immediately kicked in.
I haven't done an official runtime test, but they seem to last awhile, and 1700-1900mah sounds believable.
So at half the price of AW's, and probably around 80% of the capacity, I have found they are a cost effective alternative for single cell lights.
That is great, Larry. I used them, but have since ordered some AW's actually, and was wondering whether to throw out the Ultrafires in proper disposals, or keep them. but after what you wrote, i will get rid of them. and replace with All AW's. Thanks.
If you decide not to go with AW's cells for some reason, the 2000 mAh LG 18650s are a bangin' deal compared to the Ultrafires.
are those LG cells? beeeccaaauuse it looks like Batteryspace went all cheap on us, cause they SEEM to be GL cells instead Genxiao Li :) Peng kun Gao dun took over there,
i am not sure but a swear i used to get my LGs from battery space, but the spec sheet isnt a lg spec sheet for them anymore, they are all off brand things now?
i am so confused :mecry:
Dagnab it, I didn't notice that until you pointed it out. And I just ordered a batch yesterday. I'll update once I receive the items...
Genxiao Li :) Peng kun Gao dun took over there, i am not sure but a swear i used to get my LGs from battery space, but the spec sheet isnt a lg spec sheet for them anymore, they are all off brand things now?
Confirmed: I received LG cells in the salmon-colored wrapper.
