B BT132435 Newly Enlightened Joined Sep 3, 2005 Messages 169 Jul 24, 2007 #1 I accidently left some Ni-mh AA's in a non-plugged in charger for a few months.... For safety precautions should i throw them away?
Daniel_sk Flashlight Enthusiast Joined May 29, 2006 Messages 1,282 Location Slovakia Jul 24, 2007 #2 NiMH aren't dangerous, they don't explode - I think you can just charge them again and they should be OK. The only thing that probably happened is that they have self-discharged.
Burgess Flashaholic Joined Apr 10, 2006 Messages 6,611 Location USA Jul 24, 2007 #3 Are you thinking that perhaps sitting in the charger (not plugged in) has somehow DRAINED the cells dry ? Thereby causing damage to 'em ? Check the cells with a voltmeter. I'll bet they all register substantially higher than Zero. 🙂 -
SilverFox Flashaholic Joined Jan 19, 2003 Messages 12,449 Location Bellingham WA Jul 25, 2007 #4 Hello Daniel, A point of clairification... NiMh cells don't explode very often... 🙂 Tom
B BT132435 Newly Enlightened Joined Sep 3, 2005 Messages 169 Jul 25, 2007 #5 Burgess said: Are you thinking that perhaps sitting in the charger (not plugged in) has somehow DRAINED the cells dry ? Thereby causing damage to 'em ? Check the cells with a voltmeter. I'll bet they all register substantially higher than Zero. 🙂 - Click to expand... I thought leaving rechargeables in a charger discharges the cells 😱. Well i don't have a voltmeter =\
SilverFox Flashaholic Joined Jan 19, 2003 Messages 12,449 Location Bellingham WA Jul 25, 2007 #6 Hello BT, Some do and some don't. A volt meter is a good investment. Tom
