I will modify my question: Is 10280 safe with buck converter that needs 2.5v minimum input and outputs 400mah. 400X2.2/3.6= 244mah
That means <2C.
http://focus.ti.com/docs/prod/folders/print/tps62225.html
____________________________
ignore this:
I want to use 10280 to DD XPE red LED which is rated at 2.1V@350mah and 2.3V@700 mah. I remember reading that for such a small cell high discharge rate is ok because battery have only 180mah capacity and runtime of about 15min and will be used sparingly. I want to confirm this. Will I be destroying the the batteries?
Alternatly, I need a tiny li-ion overdischarge protection for 10180, it should be no bigger then 10-11mm diameter. is it possible to hack protected 10440?? what are my options?
That means <2C.
ignore this:
