etc
I have this UPS unit, made by APC, model is 650.
It was made in '99 and apparently not used since then, sat new in the box. When I connected a computer workstation to it, and gave it ample time to charge (2 weeks should be more than enough). A power outage came and it did not work. The unit appears to be completely non-functional.
Question, do they go bad, is there a lifetime to them? Or did it get discharged so badly it could be recharged?
There is a test button on it which I pressed and it supposedly passed, it buzzes when it does.
http://www.targetpc.com/hardware/ups/apc_650/
Edit: I need to check if the battery is connected. . . per above.
