Use m61 with Elzetta ?
american
They come stock with the m60 wich has a built in Lens. So what do you do to put a lens in the m61?
Grizzman
KC Metro
There are several different options. One is the lens kit directly from Malkoff Devices. Another option is to go to flashlightlens.com and get the Borofloat 22.61mm x 1.10mm lens or .95mm thick AR coated lens in 22.61mm diameter. A sapphire crystal with AR coating option is the 22.5mm x 1mm offering from The Sandwich Shoppe.
american
The lens from the md2 correct?
Grizzman
KC Metro
Actually, either the round Elzetta o-ring or the flat Malkoff gasket can be used. It is not necessary (or advisable) to use both of them together. I personally use the Elzetta o-ring.
