CircuitsToPlowshares
- Joined
- May 14, 2009
- Messages
- 6
I was looking at making a small light panel for a photographer friend of mine. I picked up some 10mm 140kmcd leds and an driver http://dealextreme.com/details.dx/sku.13690 . The leds have an operating range of 3.4Vf to 3.8Vf with corresponding currents of 20mA and 40mA. Since the driver is a 320 mA constant current driver with output voltage between 16-26V, I plan on putting 8 strings of 6 leds in parallel.
I assume good design would be to use a resistor on each string but I am not sure what value because I don't have a fixed voltage. My assumption was to figure on the driver putting out some voltage above the string Vf (22.8). I had planned on just figuring on ~1v at 40mA so a value of somewhere around 22ohm or 26ohm. Does this sound reasonable kind of thought process.
Edit: For clarity I wanted to drive them at 40mA.
