Using different 6P bezels
ncnative
I have just recieved Malkoff M60 and what a blaster of a module. I need some advice though, my problem is that I would like to use my Solarforce bezel with the stainless crenalations but i can't get the light to work. It will work with an extra spring around the base of the M60 but will not screw down completely (1/8" gap). Any advice on how to fix this? Many thanks ahead. I have gotten some great info from this forum but have never needed help until now.
This problem, and the solution, is already mentioned on the pages from Malkoff (Look at the bottom of the page, "Beryllium Copper Spring Washer Fitting Ring"):
http://www.malkoffdevices.com/shop2/index.php?main_page=product_info&cPath=1_14_15&products_id=35
Click the link:
http://www.malkoffdevices.com/shop2/index.php?main_page=product_info&products_id=6
A well known, and easy remedied problem.
Fivemegas's bi-pin holders also have the same problem, and he sends shims with the holders when you order from him.
Thanks for the help fellow CPF'ers. I understood the copper ring was for the shock absorbing heads, I probably should have ordered one with my module. I solved my problem with the foil temporarily until I get a copper ring.
