Vector HID
Starlight
Florida
I have a Vector HID light. I extended the battery wires out the back, with plug in connectors so I could use an external battery. I had the light turned on, but I caught the wires on something and pulled the plugs loose. I tried to plug the battery back in. I did not think to turn the switch off first. When I put the plugs back, they arced several times. Now the light doesn't work at all. Help!!
This is a picture of the bulb from the Vector. I have decided to just replace the bulb and ballast with an aftermarket kit for headlights. The only thing I need to fit in the old housing is the bulb. Can anyone tell me what bulb this is, like H3 or H7? Also, does anyone know if the Vector was a 35W or a 55W? Thanks in advance.
