Visually Impaired Sexy Man Needs Light Help
zchatila
Intro
:) Nice site you have here. I've been reading it for about a half hour now.
I am looking for a flashlight or possibly a headlight, but they look too expensive if I want proper output. So LED flashlight is probably my choice.
I filled out the questionnaire below, but here is my info, in a nutshell. I have reduced vision, especially at night, and intend on going with my photo equipment at night for shoots. Possibly, in areas where there is little to no light and up stairs.
What I need
My preference is for a flood light type effect, that illuminates a wide area. I also need something that can last 3 hours on one charge or battery, and probably at least in the range of 150 lumens, from what I've seen on YouTube and elsewhere. I've been recommended Coast by one online retailer.
Summary of Important Requirements
  1. ~150 lumens
  2. More Flood Light than narrow beam
  3. 3 hour lifespan of charge/battery
  4. Under 100$
Questionannire
A few additional ideas and likes.
0) What Region/Country/State will the light be purchased in?
__X__I will be mail-ordering or buying online, so this doesn't matter.
__X__I am in North America. More precisely I am in Montreal.
____I am in South America. More precisely I am in _______________.
____I am in Europe. More precisely I am in _______________.
____I am in the Middle East. More precisely I am in _______________.
____I am in Africa. More precisely I am in _______________.
____I am in Asia, Japan or Micronesia. More precisely I am in _______________.
____I am in Australia. More precisely I am in _______________.
1) Price Range: An easy question, but you may change your mind after answering the rest! :)
Below 100$. Cheaper the better! duh!
2) Format:
_X_I want a flashlight.
_X_I want a headlamp.
____I want a lantern.
____I want a portable spotlight.
3) Length:
_X__I don't care.
____1-2 inches. (Keychain sized)
____2-4 inches. (Pocket carry)
____4-9 inches. (Holster carry)
4) Width:
__X_I don't care.
____I prefer a long narrow light.
____I prefer a short wide light.
5) What batteries do you want to use? Alkaline batteries are easier to find and less expensive but don't pack as much stored energy and are don't work well in cold temperatures. Lithium batteries have long shelf life (10+ years, great for stored emergency lights) and are not as affected by cold but must be kept dry and are more expensive. Rechargeable start expensive, but if used frequently pay off quickly.
____I want common Alkaline batteries. (AA, AAA, C, D)
_X_I want lithium batteries. (coin cells, CR123, AAA, AA...)
__X_I want a rechargeable system. (an investment, but best for everyday use)
6) How much light do you want? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible). Select all that apply.
____I want to read a map, or find a light switch, in a dark room. (5-10 lumens)
____I want to walk around a generally paved area. (15-20 lumens)
____I want to walk unpaved trails. (40 lumens)
____I want to do Caving or Search & Rescue operations. (60+ lumens)
_X_I want to light an entire campground or dazzle an intruder. (100+ lumens)
7) Throw vs Flood: Which do you prefer, lights that flood an area with a wide beam, or lights that "throw" with a tightly focused beam? Place an "X" on the line below.
Throw (distance)----------------------|--------------X-------Flood/close-up
8) Runtime: Not over-inflated manufacturer runtime claims (like some LED lights). but usable brightness measured from first activation to 50% with new batteries.
____20 min. (I want the brightest light for brief periods)
__X_60-240 min. (1-2 hours)
__X_240-360 min. (4-6 hours)
____360+ min. (More than 6 hours)
9) Durability: Generally the old phrase "you get what you pay for" is very accurate for flashlights.
____Not Important (A "night-stand" light.)
____Slightly Important (Walks around the neighborhood.)
__X_Very Important (Camping, Backpacking, Car Glove-box.)
____Critical (Police, Fire, Search & Rescue, Self-defense, Survival.)
8) Switch Type:
__X_I don't care.
____I want a sliding switch. (Stays on until slid back.)
____I want a "clickie" switch. (Stays on until pressed again.)
____I want a momentary switch. (Only stays on while held down.)
9) Switch Location:
__X_I don't care.
____I want a push or sliding switch on the body near the head.
____I want a push switch on the back end of the body.
____I want a rotating head switch.
____I want a rotating end-cap switch.
___I want a remote control.
10) Operational Modes: Check all that apply.
__X__A simple on-off is fine for me.
__X_I want 2 light levels. (Brighter/short runtime and Dimmer/long runtime.)
____I want multiple light levels. (some lights have 5-16 light levels.)
____I want a strobe mode. (blinks to show location.)
__X_I want a tactical strobe. (Flashes rapidly to disorient an opponent.)
11) Is it important whether the body is metal or plastic/composite?
__X_I don't care.
____I want a metal-bodied light.
____I want a plastic/composite light.
12) Special Needs: Is there anything else you want or need that hasn't been mentioned? Circle any below or write in your own comment(s).
__X_Red (night vision preserving) filter
____Other filter colors (Amber, Green, Blue, _________)
____Waterproof – how deep: _____________
____Non-reflective/dark finish (stealthy/hard to find)
____Polished silver or brightly colored finish (for easy locating)
____Corrosion resistant or hard-anodized finish
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Built-in second (or spare) lamp or filament
__x_Belt/Jacket clip
____Holster
__X_Wrist/Neck Lanyard
____Kobuton/self defense features
____Non-sparking Intrinsically Safe (IS) for use in explosive environments
Thank you
Thanks ;) :)
The Fenix L2T V2.0 seems pretty good for what you are describing, besides strobe. 8% off coupon at Fenix Store/4Sevens is "CPF8". The Nitecore Defender Infinity and Nitecore Extreme has strobe and you can set the lower level.
If you loosen up the multimode thing(as in more then 2 modes) then there are more lights to choose from, but that might not be a good thing. It can take longer to decide.
:welcome:
LOL...welcome sexy man. Damm, I should have used that for my CPF user name :rolleyes:. Maybe there some mostly blind women here and I might have...well nevermind :naughty:.
Sure you will get plenty idea`s here :wave:
Coming up with solutions to these kinds of puzzles tends to be fun, so let's see what comes to my mind...
First, I'm not extensively knowledgeable about headlamps, so there may be something out there that would fit your needs, but I don't know of it. My only real experience is with ZebraLight. These are fantastic lights that excel at flood (no hotspot whatsoever). Unfortunately, though, I doubt you'd find their output quite sufficient.
So, onto flashlights:
Option 1: SureFire Kroma. Okay, so this one doesn't quite fit your criteria perfectly. It's too expensive, and it's below a hundred lumens on high. It does, however, give you red and blue LED's as well, which would be great for preserving night vision. If there were some way of modding it to have a more powerful main emitter, this would be my first pick for the job.
Option 2: SureFire 6P ($40 on eBay) with a Dereelight 3SM drop-in ($35) and a SureFire red filter (FM35, I think; ~$30). You could, of course, go with a different body, like the SureFire C2, or something, but I think the 6P is the best bang for your buck. Also, you'll need to find yourself some kind of diffusion film to place in/on the head of the light so as to have a floody beam. Very few lights out there seem to be pure flood; the Malkoff M60LF would be great, but won't have multiple modes like the Dereelight.
I know there are other lights out there that you can get red filters for, etc., so my suggestions are far from the only options.
Personally, when I'm doing nighttime photography, I use a NiteCore D10 on low for night vision preservation, and then when I really need to light things up, I use my SureFire C2 with Malkoff M60 and SF FM34 diffuser (this setup has the best flood I've seen in a light, I think).
Nothing using AAA cells will produce the amount of light you want for the length of time you want. AA cells (preferably rechargeable) will be a better choice. Headlamps are a good but, would it interfere with you taking picutes with it on your head?
I'd recommend the Priceton Tec Apex headlamp but, its stock beam is horrible. It's only acceptable when moded with a Seoul LED and reflector. Even with these mods, you may be able to get it for under $100.
Handheld lights (2AA cells have a longer battery life) from Fenix and Olight are good if not the best for the money.
Remember, the flashlight can be used for many other situations other than during your photography sessions so believe me (us) when we say that multiple (3) modes are a good thing :)
I'm.......too sexy for my light...........too sexy for my light.........sooo seeexy I'm briiiiiight! :D
:welcome:
Thanks for all the suggestions. You guys are quick and amazing. Just a few ideas:
The Fenix L2T V2.0, while I love Fenix (who does not) it says on the website that it is an intense beam of light, which does not suit my purpose.
Also, the red light is not a priority, just a nice extra. And also, the light is not necessarily photography related. I just need a light to help me see because of poor eyesight. So just please keep in mind my main criteria:
1) under 100$
2) wide beam of light, and not spot light
3) at least 150 lumens.
thanks and please, keep em coming.
p.s. i was walking home once and I stepped into some dog poop. I only found out when i got home :( Bad eyesight, see? lol.
LOL and bad nose too :crackup:
Although lights may mention 'high intensity beam', their sidespill is often more than enough to see with and are often very wide. Check out flashlightreviews.com. Quickbeam has beamshots of the lights he's reviewing. If you think of a specific light, with a bit of diging here, you'll likely find outdoor beamshots as well.
One thing you should keep in mind is that not a lot of lights are true FLOOD lights. For probably 95% or more of lights on the market, you'll have to add some kind of diffuser. Some manufacturers may offer appropriate diffusers (like the FM34 for 6P series lights). But in other cases, you'll likely have to make your own diffuser to get the true flood that you want. This can be done with unconventional things like chopped up water bottle caps in some cases, or you could find a diffuser film (like those they use in theatrical and other lighting fixtures) to put on the light's lens.
Now, as to lights designed to be floody, the ZebraLight H50 is one, but it's probably too dim for you beyond three or four feet.
Another flood light is the Malkoff M60LF drop-in for the SureFire 6P series. This should be about as bright as you need, and has no discernable "cutoff" that you get in reflector lights. The downside, of course, is cost. The drop-in is about $55, as I recall, and the cheapest host you'll get retail is the SureFire G2 at a little shy of $35. The red filter, if that's really needed, will then bring it over $100, as it'll cost another $30 or so. That said, I highly recommend this setup; it's about as durable and rugged as they come, all the parts have a fabulous warranty, and it's just an all-around great light to use.
And one last note: lights with reflectors will always have that "cutoff" line, where light is no longer cast that far out (does that make any sense?). Lights with optics, however, tend not to have as much, if any "cutoff". Instead, you get light from straight forward to fully at each side. Just in case that influences what kind of lights you look into.
I don't think we can help you until we see pictures that positively prove to us, BEYOND ALL DOUBT, that you ARE indeed sexy.
I'm thinking we're getting scammed here and that you're not really that sexy...
As for the zebralight, others here like it a lot, I didn't and returned it. Make sure you can return what you buy if the condition you return it is the same as when you received it.
George
Howdy zchatila and welcome to CPF,
Lots of good suggestions so far. Here is one that goes in a slightly different direction:
1. Maglite 3xC cell (nice size, but you could do 3xD cell if you like) ~$20:
http://www.irawoods.com/Maglite-3-Cell-C-Flashlight-Black?sc=18&category=661992
2. SSC P4 150 lumen drop-in, ~$25:
http://www.batteryjunction.com/tle-6exb.html
3. 52.1mm diffused front window (either this one, or a UCL with LDF coating) ~$5:
http://www.flashlightlens.com/str/index.php?app=ccp0&ns=prodshow&ref=acrylite_lens
4. NiMh C cells and charger combo, ~$45:
http://www.batteryjunction.com/bcqusmch4c50.html
That brings you in at about $100 including a set of rechargeable batteries. Happy hunting.
If your looking for a flood type light and not an intense spot and you said you love Fenix, then get the P2D-Q5. If you are looking for "Pure" flood then the P2D-Q5 may not be floody enough.
Its small and light wieght.
It has a large flood type spot.
It is 180 lumens on Turbo.
Also has Low, Med, High, when you don't need 180 Lumens.
It has the Strobe, plus SOS.
It is very water resistant.
You can buy the 1AA or 2AA battery tube for it. (If that Matters)
I believe it is around $60.00. Well under your $100.00 max.
Good Luck
Bill
I have amazing clairvoyant powers and can tell the OP was on a singles or hookup site before starting this thread.......:whistle:
I've been playing around with adapting a $12 SureFire F04 Diffuser to a Fenix L2D, which could work exactly the same way for the Fenix L2T. The combination of the two makes for a great diffused light that's nice and bright at the same time. The cost of this combination is way under $100 (maybe $70 to $80 at most, and only if any shipping charges are involved).
The inner diameter of the F04 Diffuser is larger than the outer diameter of the L2D, so I'm making a rubber adapter to fit between the light and the diffuser.
A really quick way to rig an adapter is to wrap three thin rubber bands several times around the head of the L2D and press the diffuser onto the head of the flashlight over the rubber bands (easy). A couple of practice tries (depending on the thickness and length of the rubber bands used) is all it takes to get a snug, non-slip fit (thin rubber bands are best). But I'm working on a much nicer adapter than that.
A couple of photos of what I'm talking about with the L2D (or similar) and the SureFire F04 diffuser:
If interested, maybe I could do a couple of comparison shots to show the difference the diffuser makes in drastically reducing the hot spot. I'm pretty sure you don't lose as much light with these nice SureFire diffusers as you might with many of the homemade jobs a lot of us come up with, but there are probably others who know a lot more about that than I do, so maybe they can provide a bit of input.
:whistle:Well he is visually impaired....
