I've been making halogen-based bicycle lights for the past couple of years, and wanted to try to make a couple LED-based lights this year. I got a tip on http://www.bikeforums.net that dealextreme.com was the place to go for materials.
Without doing a ton of homework, I hit dealextreme and ordered a few of these drivers and LEDs along with some optics/housings. Here's what showed up yesterday:
I was thinking there might be wiring diagrams, instructions, or at least an intuitive solution as to how to power the drivers, and then connect them to the LEDs, alas, I thought wrong. So, I have a couple of questions:
* Where do I connect power to the driver? I'm assuming it's to the underside, + and - being the circles on the bottom, but they're not labeled. I blew a fuse in my multimeter and am having a problem finding a replacement, so I don't have the means to do a continuity test at the moment.
* How do I connect the driver to the LED? I'm assuming it's the + and - lead coming off the driver, but the LED has two + and two - connection points, and I'm not sure if it matters which ones I use.
* Bonus question: I'm not sure if I want to make a couple single-LED lights or one 3-LED light. If I want to use 3-LEDs in one light, do I need to use 1 driver per LED, or can I use 1 driver for all 3 LEDs?
Oh, in case it matters, I plan to power the light with a 7.2v 3500mAh NiMH battery.
