Love the IMR26500, but won't fit in a MagC.
2x18650 is a typical setup for a MagC. And as you can get the
AW p26 cells, you can get more capacity out of them then the IMR cells.
I would recommend the WA1111 or ROP bulbs.
Both are configs you can run in a 2C with the 18650 without an Incan Driver and without
Also, there are more reflector options for the Rop and 1111.
Sleeving the batteries is recommended, and really easy. You can make a decent sleeve out of papertowel tube and electrical tape.
THIS CHART will give you a good idea what a 5761 can handle.
Seems you'll gain a good 700 lumens going from Lifepo4 to Li-ion.
As the bulb flashes at 7.9v you'll def need a softstart to run it off 2 Lions. And at 5+ amps it will exceed the P-26 output ability.
Are you sure you want to go 5761, it's a much more complicated build?
A Rop54 High will rival its output, and according to
THIS CHART you
SHOULD be able to build one with the P-26 cells and without the need for a softstart.
If you are willing to buy a softstart, you could go Mag85 in a 2D with 3xIMR cells. This would be the best config in my opinion for that output level. And I've personally tested it.
Within the next days I'll be writing up a Rop/11 tutorial, and a tutorial for easy sleeves.
