Based on the new info I'd say the UK Light Cannon is out. More of a medium flood than a spotlight. My modded Mags out throw it (but the LC puts out more total light if you count the larger spot and considerable spill). Also, with a $70 lamp you probably don't want to be banging it around too much.
For a dive light solution I'd say the Pelican Nemo 8C or Ikelite RCD8. Both have tight focus and pretty long throw. The 8C powered Nemo has a smoother beam and is pretty comfortable size and weight wise. The Ikelite 8D powered Super-8 RCD is big & heavy, but it has better throw and longer run time. Beam pattern is not very smooth, though. They both run in the 13-14 watt range so they are pretty bright for a battery powered light, but not as bright as the common 50-100W 12v spotlights.
There is a rechargeable 25w version of the Ikelite, but I don't know if that one will survive out of water runs.
Don't know about any corded waterproof spotlights. I imagine there are some. Probably have to check with marine/boating supply stores for that.
Lambda modded a Mag reflector to fit into a UK Light Cannon and turned it into a real
super-thrower. That should be a pretty simple mod, and it would be hard to beat for size, run time, and power. There's still the issue of banging it around. There are a lot of people that believe the HID Solarc lamp is very fragile. I have dropped and banged mine around quite a bit and I'm still on my original lamp. Others, apparently, have not been so lucky.
