KDOG3
I'm looking to get a 700-800mah driver board to run a SSCp4. I want to find the best driver board for this project. Suggestions?
Looks like the batteries connect to the underside of the board that looks like a "bullseye" and the wires connect to the LED. Yes?A quick question here: If i use for an example this board. How do I have to solder the wires ?
Yes, but I don't know about "waste" since you're getting what you want out of them, so it's more a necessary cost. Whether it's more, less, or just the same efficiency as a buck or boost board will depend on input voltage.Those boards appear to use linear voltage regulators. If so don't they waste power by dissipating the difference as heat?
At a rough guess, the positive wire (red) goes to the center of the bullseye and the negative to the outer ring. The instructions that come with it will confirm, or someone here who already owns one...I have two wires coming from the battery pack: the red and black one. I don't know where to solder them on the board.
