What cable between battery pack and unit?
4thpage
What sort of cable do you guys use between the battery and the light itself? With the light design and battery I'm using, I'm going to have two female ends. I will just solder to male ends to either end of the cable between the two...but what sort of cable? Gauge, etc?
I used 3amp 2 core round flex..I could probably use something with a lower rating but it was the lowest i could find at the time.
I think it really depends on current draw from the batterys..
Not sure what connectors your using there (unless they're bare pins) but for all my LED builds i've been using this cable and these connectors, if you're using a li-ion pack like I do then the 5 way connectors work very well for balance charging so long as you keep the charge current under 2 amps. hope this helps.:)
http://uk.farnell.com/pro-power/2182...per/dp/1387667
http://uk.farnell.com/jsp/search/bro...revNValues%3D0
These look a bit like the connecors on my Hope lights. Does anyone know if they match? I am wondering if i can use the Hope batteries that i already have..
Wire choice is heavily dependent on the current draw from the battery, how long the cable is, and how much wire loss you can tolerate. I used 18 AWG speaker wire (1.024mm diameter for you metric guys) which I had lying around to power my triple SSC P4 light from a 7.2V NiMH Sub C pack. It draws 1.6 amps from the battery. The wire resistance, according to some tables I can find, is about 7 milliohms per foot for 18 AWG wire. At 1.6A, this means I lose 11.2mV per foot. Times this by 5 feet and the total cable loss is 56mV. This is a mere 0.15% loss of voltage, which is very acceptable. I could probably go with a thinner, cheaper wire if I wanted to, but since I already had this cable, it was essentially free.
