What resistor should I use for a 1 watt bin?
What are you using the LED for? Also, Cree XR-E P4s are rated at a minimal of 80 lumen at a 350 mA drive current(The Q5 bins are over 100 lumen), the Seoul P4 U bins are a bit higher, the Edison opto KLC8 is also similar($4.40 shipped form DX).
Dealexteme and Kaidomain have cheaper driver in their DIY Flashlight section has a few cheap drivers.
There are also a few resistance calculators online(like this one)
I have tried 33 ohms and now am trying 22 ohms.
I just wish they were cheaper. I did get it on Ebay for $3 so I can't complain too much.
Here is how to make a good guesstimate.
The LED you have is a "white" so you can "guesstimate" a forward voltage of say 3.7 volts. It can vary easily from 3.5 to 4, but this is reasonably close.
5 volt supply - 3.7 volts forward voltage = 1.3 volts That is "excess" to dump.
Volts = amps x resistance
1.3 = 0.300 amps x resistance = approx 4 ohms.
Now, what power rating for the resistor ?
Power = resistance x current x current = 4 x 0.3 x 0.3 = approx 0.4 watts.
Good luck - I like resistored light setups.
