What titanium AAA are available?
Death's Head
I've seen a bunch like the Haiku, ILLUMINATI, and VersaTi. I think Olight makes one as well.
Are there others?
The Haiku is not a AAA, it's a 1xCR123 light from McGizmo. McGizmo does offer a AAA light, the Saphire. This light was/is also available from Arc with different LED options.
Other AAA Ti lights that are currently available would be the Preon 1 and Preon 2, PhotonFanatic AAA Killer, iTP Ti A3, Ti-Eiger, illuminaTi and VersaTi.
Olight's version is identical to the iTP other than the branding and it was a special holiday run so it says something like "Christmas 2009" or something.
Tom Anderson also offers both a 1xAAA and 2xAAA light, but his are actually Ti housings in which he has press fit either a Fenix LD01 or an LD05, respectively.
Unfortunately the ultimate AAA Ti is no longer available, kuku427s LF2XTi is absolutely phenominal! You could beg for one on the B/S/T, but you'd have to get in line behind several others who have had 0 luck.
Two discontinued models that sometimes surface over at the mp are the Fenix Lo-Ti and the Muyshondt Mako.
Here's an older photo of some of my Ti AAAs:
Left to right: VersaTi, illuminaTi, Mako, iTP A3, LF2XTi, Preon 1 (clicky), Preon 1 (twisty), Lo-Ti, Saphire, Killer, illuminaTi, VeraTi and a Preon 2 in front. The two VersaTis have a different UI, one is low first and the other is high first. The two illuminaTis are identical, one for edc with the Ti Dangler attached and the other to just look pretty. I have added a Ti-Eiger to my collection since this picture.
Other than the ones in the photo and the ones I've mentioned, I can't think of many other AAA Ti lights that exist. There's a AAA body for the Drake/Draco from modomag and Muyshondt had the Zephyr that never made it into production. :thinking: I think that about covers it.
Out of the readily available models, I prefer either the illuminaTi or the Preon 2 for edc.
I think Incidentalist covers about all. :thinking:
Hello!
Please, what is model just to left of colorfully anodized light??
Thanks & regards,
Chuck :wave:
Hi folks with the IlluminaTi AAA,
How is the lanyard hole holding up on yours? Do you use it with a split ring? The amount of material on mine seems thin and not very substantial.
Looks like run #3 of the LF2XTi. The first run had a plain head, next was the stock-look head and finally the fully knurled head.
I thought the one in HKJ's pic's is from the last run. :thinking:
Unless I screwed up the fully knurled head was the 3rd and last run of Ti units.
I believe mine is from the second run. Incidentalist is from the 3. run.
That means that you've got the same one I do, which in my opinion is the best, which I lucked into with no realization that I would think so later!
