What's the size of SSC P7 core? A reflector for the answer!
neoseikan
I am designing the reflector for ssc P7, but I have not enough samples.
Is there any one who has removed the lens on SSC P7?
Only take this as a guess. I'm judging by the pictures and the info given on the spec sheets.
2.1 - 2.3mm(each die is ~ 1mm, + space in the middle). Probably closest to 2.1mm.
Have you tried contacting Seoul?
here you go http://www.led-professional.com/content/view/930/29/
Assuming that the P7 uses the same chip footprint as the rest of its Z-LED brothers, I'd refer to this datasheet
as of yet though, Seoul hasn't released the internals, even today luxeon datasheets don't tell you the exact size of the dies. I did a search on it off the forum and it was one of few times where all google was able to pull up was earlier discussions from CPF:poke:
Thanks! lads.
I will try to ask SSC themselves.
When I complete the reflector, I will send it to you.
Probably 4x1mm^2 dies.. I think 1mmx1mm is standard die size. From that info you could determine the size of the gap between them with that picture. As looking through the dome will result in a larger image of the die than really is there of course.
My two P7's arived today, and I drug out some stuff. Stock 3D gag, a fairly deep reflector and bezel from I forget who, and a 5200 mah (unprotected) LiIon Dcell. :D Maybe this weekend. The other will go into a desert getaway shack lantern lightng.
Larry
Anybody know how to use the .RS7 file with Trace pro?
I haven't the software Prosource.
as long as the water isn't salty its more or less a non-capacitive insulator that not only prevents shorts but also keeps air off the phosphor surface and decrease oxidation from reducing the life of the emitter
I was told a "true" mule involves lighting up the LED under water, where the refraction of the dome is countered by the refracted properties of water.
Larry
Does the P7 fit through the hole in the stock G@g reflector?
