I like the LiteFlux LF5. It runs great on a 14500 and it has an overdischarge mode built in to protect your batteries. That allows you to use the higher capacity unprotected cells. I believe it runs at about 750ma draw with a 14500. If you switch to regular AAs, the current pull drops to 350ma.
If the LiteFlux LF5 has an overdischarge feature, how could it work with regular AAs that are below the cutoff voltage for L-Ion?
Dr.Glock27 said:Have you tried the 14500 on a fenix L1D R80 or the L1T R80 or R100?
Rexlight :thumbsup:
Apparently, the light "senses" if it's a NIMH/Alki or a LiOn, and adjusts accordingly.
Which actually makes sense. If your LiOn is down around 1.5v, you're in trouble. So if the voltage is 1.5v, must be an alki.... 1.2v, must be a nimh - then it sets the overdischarge accordingly.
Kai claims the new build 001 corrects the reflector focus. Don't have one to test, though.What are your thoughts on the Rexlight 2.1? I read it's beam wasn't quite as smooth as the 2.0. Also, I like the idea that it has a low low. But is it really that low? Hoping so. . .
Hi,
this is not an attempted hijacking of the thread. i'm sure people will get right back on the main topic.
is the 14500 not the common AA battery?
Mike
Hi,
Mike
