What are the characteristics of a cell nearing the end of its safe or useful life? It will help greatly if I don't need fancy equipment to figure this out.:thinking:
I was hoping for a sticky on this topic or a link in Threads of Interest but I couldn't find one.
I have some 2 or 3+ yr old LiIon Rcr123's. Some blue label ones, AW and Battery station.
I've noticed that my WF139 charger has never charged these over 4.17v, even when everything was new. I pull them when the light turns green and as a backup I have a pin-type timer connected to it to automatically cut power after about 3hrs from start.
I thought I might get a little better safety and performance by getting a Pila IBC which I received from Kitelites GB last week (great guy to deal with).
When I put the batteries in the Pila the max voltage on the best battery after removal is less than the WF 139 by about 0.02v. In example case about 4.15v. Some of them are lower. I think the worst was about 4.09v.
My first thought was that the Pila was bad. But I'm now thinking its the batteries after reading some silverfox comments in other threads. I thought that if a charger charges to 4.20v that meant that the batteries would come off at 4.20v, but I may have been mistaken.
I have also read that LiIon cells can loose 50% of their capacity over the course of 3 yrs whether they are used or not.
Also when using my Ra170cn flashlight most of the batteries will trip off the low battery indicator and upon removal will read about 3.24v. Battery Station Rcr123 (BS2) has a shorter runtime and upon removal will read 3.66v or so.
The runtimes I have are:
BS1 = 59 min (bought May'07)
BS2 = 49 min (bought Dec '06, end voltage 3.66v)
AW1 = 55 min (bought Dec '07)
AW2 = 63 min (bought Dec '07)
The testing equipment I have at my disposal is the Pila, a voltmeter, and the Ra flashlight. I have no way to drain cells except for flashlights.
Thanks, and hopefully the resulting discussion will achieve sticky status!
