@NightRider: Thanks for the welcoming, behonest your project logs have put the nail in the coffin for my internal struggle about rather to build my own light or buy a kit from master modders on CPF. And I thank you for your inspration and good info.
@Doh!Nut: Thanks for the time and effort in all the calculations you have done for me. I started to have more concrete specifications for my project hopefully I can get the light designed and all the parts sourced somewhere so that I can use it before the winter is gone. I don't really like flashing front light coz it dazzles me, but I am ok for the back light to flash coz it is not dazzlling me
I think I want 2 maybe 3 levels of lights, so maybe 350mA, 750mA and 900mA or something I need to fix these current points by looking more closely at the lumans vs. current graph.
Question:
- How do you convert Wh into mAh?
- Are there safe Li-Ion battery packs out there that can support the following battery requirement?
- How does the light level works with the drivers? Do I do one click to Low, one more to medium and one more to max level?
- Battery calculation:
Say I need to have 750mA for 7hrs runtime @ 12V then:
Battery Capacity in mAh = RunTime X Driving Current
Battery Capacity =750mA x 7hrs = 5250mAh
10 * 1.2V@2700mAh in
series will give me 12V@2700mAh then
2 * 12V@2700mAh in
parallel will give me 12V@5400mAh
Therefore the required battery ratings for this project and I need 20
of those 1.2V 2700mAh AA cells then. Please check calculation!!
Now I am thinking of machining the casing for my light, I don't have access to any machines I can only do simple screw driver type of things. So if anyone can offer machining service I would love to hear from you.
Paul
