Where to buy p60 drop-ins?
Labrus
I want to buy a few drop-inmodules with MCE/P7. Each will be driven by a 18 650, ie max 4.2 V. The modules will be sitting in chilled aluminum with high thermal mass.
I am also grateful for tips on good drop inmodul MCE/P7 with 2 pcs
18 650 / 2P2S 18650.
Many thanks in advance
/Labrus:grin2:
Thanks for the advice, then I found a great drop-in with one MCE and one 18650
Can someone help me if I specify more clearly about the MCE/P7 powered by 2 pcs 18 650?
I want drop-ins with the tight beam, narrow-angle. Preferably a bit cold light, more than 5000K. Preferably with just one mode, high, from the driver, but two or three modes Nm94T8works. Where can I buy?:)
P60 Drop in ? 8.4v driver ?? SSC P7 with a tight beam ??
Sorry , :faint: , if you want a tight beam , XR-E R2 , or wait to see what the new XM emitters do ...
If there is no good or at least sensible solution for MCE and 8.4 V, perhaps you can provide best solution for drivers and MCE?
Preferably one, high, fashion, but good quality driver .. I would also appreciate a pcture on the wiring ..
Thanks!:grin2:
