Sold/Expired Where to find some PCBs?
Lumencraft (Matt)
Vendor
Missouri
Hey all,
I was just wandering if anyone knows where I can find a few parts?
EDIT: First item found.
The first thing I would like to have is some of those small round discs that come in most lights that use an XRE emitter. It goes around the emitter to insulate it from the metal reflector. I could use a lot of these.
Second I could use some small MCE pcbs. 14, 15 or 16mm would be great. All I can find is 20MM. I could also use some for XRE the same size.
I know this last one is a stretch but I wouldn't mind having some 17MM round PCB for blank driver boards, rather than having to remove chips from a good one. I actually had my hands on a double sided round 17mm PCB once, it came with a TLS C to M adapter with a spring attached to it.
Re: Where to find some parts?
That appears to be one of the parts I mentioned, but the price sure is a lot higher than I was thinking. 2 dollars each :shakehead. Doesn't make sense when I need about 20 of them.
Got some of the discs orderd, but I could still use some 15MM PCBs for MCE, and maybe a couple for XREs.
