crofty
Trying to figure out what battery to use in our cooker ignition. It uses a single AA and for the last year it`s had a uniross hybrio in it which was new when it went in and has been charged a few times, probably no more than 5.
Recently I noticed it could do with a charge so I charged it up and a few weeks later noticed the ignition wasn`t as lively as it used to be so soon after a charge. On the charger it went again this time for a refresh and it came of at 1834. I`ve got other hybrios of the same age which have had regular cycles that still measure around 2200 so that was disapointing.
Why it`s lost so much capacity I don`t know, but it could explain why the ignition isn`t as strong, for as long as it used to be.
So what are my options? I`m thinking to use an eneloop or an Energizer Ultimate Lithium. The holder on the cooker has put a pretty big dent in the negative end of the hybrio so I`m reluctant to just try an eneloop in it before getting a lithium if need be.
The reason I`m considerring an eneloop or Energizer Lithium is because even before this hybrio went down hill, hot of the charger the ignition has plenty of life in it, it goes click click click fast and strong, but after the voltage settles down it`s noticable slower and weaker. Still very useable but I wonder if an eneloop or a lithium would be a better.
I guess it needs a battery that can deliver a good punch under load for short bursts.
What are the options then, eneloop, lithium or any others?
Breifly considered a 14500 but I don`t know if the cooker could handle the extra voltage and anyway, a proper lithium so close to all that heat doesn`t sit too comfortably
Thanks
crofty
Thanks
crofty
