Hello-
I'm in the market for a more versatile battery charger. I'm currently only using a LaCrosse BC-900 for AA/AAAs. My primary impetus is that I need to charge some C and D size NiMH batteries. A secondary goal might be the ability to charge more than 4 AAs at a time, and/or possibly Li-Ion cells.
The two contenders:
Maha MH-C808M
Hyperion EOS 5I DP (although I'm willing to entertain any sub-$250 RC charger)
Pros of the Maha:
Cheaper. Can charge 8 cells simultaneously with separate charging channels. Standard cells can be changed/charged quickly and without any complexities.
Cons of the Maha:
Can't do Li-Ion. Can't do non-standard size NiMH.
Pros of the Hyperion:
Can do up to 14 NiMH cells simultanously (including my FM 3D-9AA holder). Can do Li-Ion. Can do any size battery with appropriate holder.
Cons of the Hyperion:
Only one charging channel. Requires battery holders to do most types of charging.
Since 95% of my charging needs will be primary sizes (AA/C/D), I'm really considering the convenience of the Maha. However, with the appropriate battery holders, I think the Hyperion will only be slightly less convenient, but adds considerable extra functionality in return.
Another concern, which may be large enough for its own thread: Is it better to charge 4 cells in series on a single channel or each on its own? I always assumed that putting each cell on its own channel was the safest and easiest way to get them a full charge.
Any thoughts would be appreciated.
The two contenders:
Maha MH-C808M
Pros of the Maha:
Cons of the Maha:
