tre
I'm thinking of building myself a cusom light. I thought it was a no brainer to use a 6000mah NiMh C cell but....
If my calculations are correct:
LiCo capacity = 3.6v * 2.9ah = 10.44wh
NiMh capacity = 1.2v * 6.0ah = 7.2wh
Power to the LED will be about 5.4 watts.
If I use a 1.5 amp driver and a 2900 cell, I calculate:
1.5amps x 3.6vlots = 5.4 watts
To get the same 6.3 watts of power from a 1.5 volt NiMh C cell I need a 4.2amp driver:
1.2 volts * 4.5amps = 5.4 watts
If I use a 85% efficient driver
5.4w / .85 = 6.35w
Run time for my 2900 Redilast would be: 12.18wh / 6.35w = 1.92 hours
Run time for my 6000mah NiMh cell is: 9wh / 6.35w = 1.41 hours
so it looks like a 2900mah LiCo cell will run my light (most lights?) longer than a 6000mah NiMh C cell. Does this seem correct?
5.4w / .85 = 6.35w
